NAS326 assign drive letter
i have just assigned static ip on all boxes and uninstalled NSU.. and rebooted both pc and nas's, now i cant connect to any of the boxes through explorer
Dangling sessions? In Windows you can view your sessions withnet sessionand you can delete all sessions withnet session /delete(Don't know if you need an elevated command prompt for that, as you can initiate a session as ordinary user I guess not)
do you know how i can fix it? im not winows expert, so a bit of noob explanation might be needed
this is the error i get when i try to access it through explorer
could the raid have been "destroyed" after the power outtage and i might have to create new partitions?0 -
i have also tried diagnose without success0
do you know how i can fix it? im not winows expert, so a bit of noob explanation might be neededWell, if a dangling session is the problem, then executing 'net session /delete' from a Windows command prompt should be the solution.The problem is clearly on the client side, as uninstalling NSU blocked your other 3 boxes, while that boxes didn't change. Unfortunately I'm not a Windows expert either.You still didn't answer my question if you ever changed the hostnames of the NASses. If not, make sure you do it.0
how do i change hostnames?0
Somewhere in the Config Panel. I think in the network section. Hostname, servername, something like that. The default value for a NAS326 is -surprise!- nas326.
yes.. ive changed all of those
In that case I'm out of ideas, I'm afraid. Maybe the logs in Windows can tell you more, but I don't know where to find them. (Except of 'event log').When it worked with NSU you could reinstall that, and if 'the other 3' start working again you could downgrade the 4th.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
