LTE5388-M804 loses network after some time
Excellent work! This is much better than my brute force Web UI approach. I'll give a try and reports back.
v1.0.1: script updated to handle low SNR and use RX vs. TX for detection 😂
I've tested today with a VM, and aparently "expect" package can be installed on pfSense without other dependency (of course you must enable Freebsd packages). It sounds a reasonnable risk to add this single unofficial package, at least it won't require a thousand other packages to be installed on the firewall. Of course, it could be a better solution to audit the code and/or ask Netgate to add the package in a future release.
v1.0.3: fixes to handle several situations like wwan0 interface missing, connection Down…
Remember to adapt thresholds depending on whether you have enabled IPv6 or not, because there is much less data received in pure IPv4 with a non-routable address, and of course to modify your IPv4 address and SSH passsword. The script requires "expect" command, available on MacOS (natively), FreeBSD (including pfSense if you enable FreeBSD packages), Linux. Several ports also exist for Windows. For LTE5388-M804 and LTE5398-904.
any updates on this from zyxel?
without a firmware fix we are left with the temptation to jailbreak the device and login with supervisor user and do it ourselves, but frankly it would be nice to see a fix given one was ready made by JeanFrancois0 -
To whom it may concern, v1.0.5 with minor improvements.
As always, remember to adapt thresholds depending on whether you have enabled IPv6 or not, because there is much less data received in pure IPv4 with a non-routable address, and of course to modify your IPv4 address and SSH passsword. Don't forget to save your configuration with zycli save_default save otherwise reboot will lead to reset to the factory settings! Use at your own risk.
I received a first beta version of a bugfix yesterday, but within ~30hrs the problem presented again.
Good news is, a fix seems to be on the way.
I wouldn't know what the fix is about exactly, but during the lifespan of my support ticket there's been a lot of talking about a "watchdog" which should have to do with the idea on this thread.
same issue with router LTE5398-M904, firmware V1.00(ABQV.4)C0 (28 oct.2023)
and LTE module firmware EG18EAPAR01A12M4G_01.001.01.001
I have lost all hope that the Zyxel development team can (or actually want to) fix the issue.
(tested in Italy with Vodafone, Iliad, Postemobile, Wind3, HoMobile, Fastweb, VeryMobile)0 -
Is there any new on this issue ?
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
