NAS 540 ethernet ports not working
Hello, I have a nas540, which apparently the two Ethernet ports have stopped working. I have reset the Nas to factory mode. the beeps are ok, but the ethernet ports are still off. Any way to access the nas by USB port?
  • Mijzelf
    Mijzelf Posts: 2,960  Guru Member
    I'm afraid not. Have you also tested the cable and the switch?
  • jcperez
    jcperez Posts: 2
    Thank you for answering
    Yes I have changed the cables, and the ports on the switch, without any result. (the two ethernet ports continue with the leds off). I have also changed the power supply for another with the same voltage.
    Without any result.
    So it looks bad.
  • Mijzelf
    So it looks bad.
    Yes. Do you have the possibility to try another powersupply?
