NR7101 does not accept Username and Password after factory reset
BrandSafway
BrandSafway Posts: 22  Freshman Member
edited January 2024 in Mobile Broadband
Hi Zyxel Team,
i have setup a Zyxel NR7101 and upgraded it to the following device and modem module firmware successfully:
Router Firmware: 1.00(ABUV.5)C0
Modem Firmware: RG502QEAAAR11A07M4G
After having just changed some wifi settings it started to reset the WAN connection every 30 seconds and kept kicking me out of the configuration page due to "network change detected".
I then followed with a factory reset on the device. Pressing the button for 15 seconds.
Now im faced with the issue when i try to login via http://192.168.2.1/login
i keeps saying username or password wrong.
Username: admin
Password: 1234
i have also tried the default password that is printed on the label and worked with the initial setup. It run the factory set twice. Still facing the issue that the username/password is wrong.
I'm unable to login into the configuration page.
Please advise. Im unaware of any new default username/password shipping with the above firmware!
Regards!
