Wifi Connection but randomly no internet
maxna
maxna Posts: 9
Using 6 Zyxel Cloud WiFi6 AX1800 Wireless Access Point [NWA50AX] with one Zyxel 8-Port Gigabit PoE Switch [GS1900-10HP]
clients are connected to the wifi network but randomly cannot connect to the internet
plase advise what the issue for this could be
«1
  • Zyxel_Nami
    Zyxel_Nami Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @maxna
    Please check if the end devices have received an IP address after connecting to the WiFi network. If the devices haven't received an IP address, please verify that the Switch and Router/Gateway/DHCP server are configured correctly for VLAN and DHCP.
    Could you also specify if this issue is affecting all end devices or only specific ones? Please share the MAC addresses of the affected devices via private message by clicking on my name and selecting 'Message'.
    Alternatively, you may enable Zyxel Support Access to facilitate our assistance.
    Nami
  • maxna
    maxna Posts: 9
    hi
    dhcp is enabled
    this randomly affects all kind of devices windows/mac + adroid/ios
    i will enable Zyxel Support Access now
  • Zyxel_Nami
    edited May 2024
    Hi @maxna
    ⇒ When you mention this, are you referring to clients that show as connected to an SSID but somehow can't reach the Internet, or are the clients completely disconnected from an SSID altogether?
    If it is the first issue, please help us with the following ping checks. This test can help identify which parts are experiencing failures:
    • Ping the connected NWA50AX (identify the AP using the Clients tab)
    • Ping the GS1900-10HP switch
    • Ping your gateway
    • Ping 8.8.8.8
    Let us know at which device the ping fails. Ensure that your PC allows incoming ICMP packets.
    Additionally, your Nebula site shows 5 of 6 APs running at 100M link speed. Please refer to the this FAQ to understand and potentially resolve this status.
    In the meantime, considering the presence of numerous IoT devices on your site, most of which are likely connected to the 2.4GHz band, optimizing wireless configuration is crucial. Here are some tips:
    • Configure the dedicated SSID for your IoT devices, enabling only 2.4GHz band only. Please refer to this FAQ
    • Adjust Maximum output power with Deployment selection, following the below screenshot and this FAQ
    Nami
  • maxna
    maxna Posts: 9
    thank you
    yes - clients that show as connected to an SSID but somehow can't reach the Internet
    following the ping results, no ping failed
    i was not abel to find out the IP of the switch
    APs seem ok
    8.8.8.8 seems slow to me
    i am aware of the issue of the APs running at 100M link speed - also this seems random - it has worked and then suddenly it changed to orange without any phisical changes
    now i changed the cable on one AP and this is also green now - but the other one was orange for a while now green again
    could this be related to the ports of the switch?
    anyhow also with orange APs we always had connectivity - now some devices connect to SsID but not reach internet
    i also changed all APs that are connected to IoTs to 2,4 only…
    please advise
    foyer
    PING 192.168.0.1 (192.168.0.1): 56 data bytes
    64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=4.234 ms
    64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=3.740 ms
    64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=6.692 ms
    64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=3.494 ms
    64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=8.025 ms
    64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=3.199 ms
    64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=3.366 ms
    64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=7.893 ms
    eventraum
    64 bytes from 192.168.0.141: icmp_seq=0 ttl=64 time=6.909 ms
    64 bytes from 192.168.0.141: icmp_seq=1 ttl=64 time=3.308 ms
    64 bytes from 192.168.0.141: icmp_seq=2 ttl=64 time=3.745 ms
    64 bytes from 192.168.0.141: icmp_seq=3 ttl=64 time=7.302 ms
    64 bytes from 192.168.0.141: icmp_seq=4 ttl=64 time=4.436 ms
    64 bytes from 192.168.0.141: icmp_seq=5 ttl=64 time=7.126 ms
    64 bytes from 192.168.0.141: icmp_seq=6 ttl=64 time=3.612 ms
    64 bytes from 192.168.0.141: icmp_seq=7 ttl=64 time=3.582 ms
    buero
    PING 192.168.0.234 (192.168.0.234): 56 data bytes
    64 bytes from 192.168.0.234: icmp_seq=0 ttl=64 time=7.051 ms
    64 bytes from 192.168.0.234: icmp_seq=1 ttl=64 time=3.581 ms
    64 bytes from 192.168.0.234: icmp_seq=2 ttl=64 time=3.619 ms
    64 bytes from 192.168.0.234: icmp_seq=3 ttl=64 time=3.613 ms
    64 bytes from 192.168.0.234: icmp_seq=4 ttl=64 time=3.790 ms
    64 bytes from 192.168.0.234: icmp_seq=5 ttl=64 time=3.524 ms
    64 bytes from 192.168.0.234: icmp_seq=6 ttl=64 time=3.584 ms
    64 bytes from 192.168.0.234: icmp_seq=7 ttl=64 time=3.562 ms
    64 bytes from 192.168.0.234: icmp_seq=8 ttl=64 time=3.558 ms
    64 bytes from 192.168.0.234: icmp_seq=9 ttl=64 time=3.526 ms
    64 bytes from 192.168.0.234: icmp_seq=10 ttl=64 time=3.538 ms
    64 bytes from 192.168.0.234: icmp_seq=11 ttl=64 time=7.295 ms
    64 bytes from 192.168.0.234: icmp_seq=12 ttl=64 time=3.300 ms
    64 bytes from 192.168.0.234: icmp_seq=13 ttl=64 time=3.235 ms
    64 bytes from 192.168.0.234: icmp_seq=14 ttl=64 time=3.707 ms
    coworking
    PING 192.168.0.252 (192.168.0.252): 56 data bytes
    64 bytes from 192.168.0.252: icmp_seq=0 ttl=64 time=3.962 ms
    64 bytes from 192.168.0.252: icmp_seq=1 ttl=64 time=3.068 ms
    64 bytes from 192.168.0.252: icmp_seq=2 ttl=64 time=3.436 ms
    64 bytes from 192.168.0.252: icmp_seq=3 ttl=64 time=3.487 ms
    64 bytes from 192.168.0.252: icmp_seq=4 ttl=64 time=3.377 ms
    64 bytes from 192.168.0.252: icmp_seq=5 ttl=64 time=4.223 ms
    64 bytes from 192.168.0.252: icmp_seq=6 ttl=64 time=5.887 ms
    foyer
    PING 192.168.0.87 (192.168.0.87): 56 data bytes
    64 bytes from 192.168.0.87: icmp_seq=0 ttl=64 time=5.918 ms
    64 bytes from 192.168.0.87: icmp_seq=1 ttl=64 time=2.389 ms
    64 bytes from 192.168.0.87: icmp_seq=2 ttl=64 time=3.021 ms
    64 bytes from 192.168.0.87: icmp_seq=3 ttl=64 time=2.823 ms
    64 bytes from 192.168.0.87: icmp_seq=4 ttl=64 time=3.011 ms
    64 bytes from 192.168.0.87: icmp_seq=5 ttl=64 time=2.106 ms
    64 bytes from 192.168.0.87: icmp_seq=6 ttl=64 time=4.860 ms
    64 bytes from 192.168.0.87: icmp_seq=7 ttl=64 time=6.185 ms
    64 bytes from 192.168.0.87: icmp_seq=8 ttl=64 time=2.809 ms
    64 bytes from 192.168.0.87: icmp_seq=9 ttl=64 time=3.002 ms
    64 bytes from 192.168.0.87: icmp_seq=10 ttl=64 time=2.909 ms
    stadtakademie
    PING 192.168.0.144 (192.168.0.144): 56 data bytes
    64 bytes from 192.168.0.144: icmp_seq=0 ttl=64 time=7.326 ms
    64 bytes from 192.168.0.144: icmp_seq=1 ttl=64 time=7.280 ms
    64 bytes from 192.168.0.144: icmp_seq=2 ttl=64 time=3.867 ms
    64 bytes from 192.168.0.144: icmp_seq=3 ttl=64 time=3.838 ms
    64 bytes from 192.168.0.144: icmp_seq=4 ttl=64 time=3.324 ms
    64 bytes from 192.168.0.144: icmp_seq=5 ttl=64 time=7.181 ms
    64 bytes from 192.168.0.144: icmp_seq=6 ttl=64 time=3.533 ms
    64 bytes from 192.168.0.144: icmp_seq=7 ttl=64 time=7.343 ms
    64 bytes from 192.168.0.144: icmp_seq=8 ttl=64 time=7.373 ms
    64 bytes from 192.168.0.144: icmp_seq=9 ttl=64 time=3.443 ms
    64 bytes from 192.168.0.144: icmp_seq=10 ttl=64 time=3.493 ms
    64 bytes from 192.168.0.144: icmp_seq=11 ttl=64 time=3.475 ms
    64 bytes from 192.168.0.144: icmp_seq=12 ttl=64 time=3.599 ms
    kaiserssal
    PING 192.168.0.17 (192.168.0.17): 56 data bytes
    64 bytes from 192.168.0.17: icmp_seq=0 ttl=64 time=7.085 ms
    64 bytes from 192.168.0.17: icmp_seq=1 ttl=64 time=3.417 ms
    64 bytes from 192.168.0.17: icmp_seq=2 ttl=64 time=7.016 ms
    64 bytes from 192.168.0.17: icmp_seq=3 ttl=64 time=3.330 ms
    64 bytes from 192.168.0.17: icmp_seq=4 ttl=64 time=3.435 ms
    64 bytes from 192.168.0.17: icmp_seq=5 ttl=64 time=3.624 ms
    64 bytes from 192.168.0.17: icmp_seq=6 ttl=64 time=7.720 ms
    64 bytes from 192.168.0.17: icmp_seq=7 ttl=64 time=8.469 ms
    64 bytes from 192.168.0.17: icmp_seq=8 ttl=64 time=8.003 ms
    64 bytes from 192.168.0.17: icmp_seq=9 ttl=64 time=7.946 ms
    64 bytes from 192.168.0.17: icmp_seq=10 ttl=64 time=3.406 ms
    64 bytes from 192.168.0.17: icmp_seq=11 ttl=64 time=4.271 ms
    64 bytes from 192.168.0.17: icmp_seq=12 ttl=64 time=3.588 ms
    64 bytes from 192.168.0.17: icmp_seq=13 ttl=64 time=7.308 ms
    64 bytes from 192.168.0.17: icmp_seq=14 ttl=64 time=3.995 ms
    64 bytes from 192.168.0.17: icmp_seq=15 ttl=64 time=3.416 ms
    64 bytes from 192.168.0.17: icmp_seq=16 ttl=64 time=3.467 ms
    64 bytes from 192.168.0.17: icmp_seq=17 ttl=64 time=3.506 ms
    64 bytes from 192.168.0.17: icmp_seq=18 ttl=64 time=3.297 ms
    64 bytes from 192.168.0.17: icmp_seq=19 ttl=64 time=4.044 ms
    PING 8.8.8.8 (8.8.8.8): 56 data bytes
    64 bytes from 8.8.8.8: icmp_seq=0 ttl=118 time=17.181 ms
    64 bytes from 8.8.8.8: icmp_seq=1 ttl=118 time=17.772 ms
    64 bytes from 8.8.8.8: icmp_seq=2 ttl=118 time=19.226 ms
    64 bytes from 8.8.8.8: icmp_seq=3 ttl=118 time=20.135 ms
    64 bytes from 8.8.8.8: icmp_seq=4 ttl=118 time=19.743 ms
    64 bytes from 8.8.8.8: icmp_seq=5 ttl=118 time=17.389 ms
    64 bytes from 8.8.8.8: icmp_seq=6 ttl=118 time=21.009 ms
    64 bytes from 8.8.8.8: icmp_seq=7 ttl=118 time=22.061 ms
    64 bytes from 8.8.8.8: icmp_seq=8 ttl=118 time=21.927 ms
    64 bytes from 8.8.8.8: icmp_seq=9 ttl=118 time=21.579 ms
    64 bytes from 8.8.8.8: icmp_seq=10 ttl=118 time=21.166 ms
    64 bytes from 8.8.8.8: icmp_seq=11 ttl=118 time=20.836 ms
    64 bytes from 8.8.8.8: icmp_seq=12 ttl=118 time=21.662 ms
    64 bytes from 8.8.8.8: icmp_seq=13 ttl=118 time=17.122 ms
    64 bytes from 8.8.8.8: icmp_seq=14 ttl=118 time=25.239 ms
    64 bytes from 8.8.8.8: icmp_seq=15 ttl=118 time=18.298 ms
    64 bytes from 8.8.8.8: icmp_seq=16 ttl=118 time=21.048 ms
    gateway
    64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=3.681 ms
    64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=3.653 ms
    64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=6.839 ms
    64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=4.335 ms
    64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=3.304 ms
    64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=4.635 ms
    64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=3.428 ms
    64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=7.044 ms
    64 bytes from 192.168.0.1: icmp_seq=8 ttl=64 time=7.525 ms
    64 bytes from 192.168.0.1: icmp_seq=9 ttl=64 time=3.415 ms
    64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=4.839 ms
    64 bytes from 192.168.0.1: icmp_seq=11 ttl=64 time=4.328 ms
    64 bytes from 192.168.0.1: icmp_seq=12 ttl=64 time=3.787 ms
  • maxna
    maxna Posts: 9
    hi
    can you please check this
  • Zyxel_Nami
    edited May 2024
    Hi @maxna
    ⇒ To locate the IP of the switch, you can use the ZON Utility. You can download it from here. However, there's no need to ping the switch now, as all connections to the gateway and 8.8.8.8 are fine.
    ⇒ I noticed that you have configured both SSIDs to use the 2.4GHz band. This means there is no 5GHz band available, limiting devices with 5GHz capabilities from connecting to the faster band, which is suitable for mobile devices, laptops, etc.
    I recommend the following setup:
    1. Choose one SSID exclusively for the 5GHz band.
    2. Choose another SSID exclusively for the 2.4GHz band.
    3. Allow IoT devices to connect to the 2.4GHz SSID.
    4. Allow 5GHz capability devices to connect to the 5GHz SSID.
    The APs themselves will broadcast both SSIDs unless otherwise specified.
    You can check their capability at Clients > Access point clients > 'Capability' tab. Devices that support 802.11ax/ac are dual-band devices, while devices that support 802.11b/g are limited to the 2.4GHz band.
    Regarding the end device you messaged, did you perform the ping test for it when the issue was occurring?
    The below logs showed that it disconnected itself from the SSID at a signal strength of -61dBm. Initially, its signal strength fluctuated from -78dBm to -68dBm, suggesting that the device may have been searching for a better signal but couldn't find a suitable one.
    To allow the end devices to connect and roam smoothly between each AP, the deployment should be checked and adjusted, especially in a multiple AP setup. Some points to consider:
    Nami
  • maxna
    maxna Posts: 9
    thank you
    if i set u the IoT devices in a seperate SSID will they still be able to communicate with a client in another SSID?
    eg printer, speaker etc
    will check for the other points?
    but how can this be related to the connectivity issues?
    why did the AP "coworking" go back to orange status since friday? noting changed in the setup
  • Zyxel_Nami
    Hi @maxna
    if i set u the IoT devices in a separate SSID will they still be able to communicate with a client in another SSID?
    ⇒ They can communicate with clients on another SSID as long as both SSIDs are configured in the same VLAN and subnet, as in your case.
    ⇒ Are you referring to the separate SSIDs, signal overlap, or output power?
    ⇒ The orange status could be due to various reasons such as cable quality or the uplink device. We checked the AP via SSH remote, and it now shows the AP running at 100M.
    You may check the Switch ports' status at Monitor > Port > Port > Status as the screenshot below to verify the speed.
    Nami
  • maxna
    maxna Posts: 9
    hi
    changed to power output of the APs also created a new 5ghz only ssid - issues still happening
    just messaged you the mac adress that just had problems (now randomly connected and working)
    issue seems to appear to devices that have not been connected to the network previously…
  • Zyxel_Nami
    edited May 2024
    Hello @maxna
    I received your message. It looks like the end device was attempting to connect to the SSID "Coworking" (dedicated 5GHz) on AP "Kaisersaal" but failed, as shown in the below screenshot. This indicates that the authentication process was not completed. Please double-confirm that the password was entered correctly.
    If the password has been already correct, we should consider the channel utilization of the AP "Kaisersaal". Please see the below screenshot of AP Kaisersaal's Channel Utilization on May 13, 18:30 (UTC+2) (= 16:30, UTC+0) in the "Access point usage and connectivity" section. The data shows that the 2.4G channel utilization is at 82%, which is quite crowded. Also, you can see that the usage of 2.4GHz is consistently within 60-80% at all times, and higher compared to 5GHz, which may result in poor connections.
    It is suggested to try configuring these settings in[Configure > Access points > Radio settings] and observe if it helps:
    Best regards,
    Nami
Nebula Tips & Tricks
