Device error, Wrong CLI command, device timeout or device logout.
Dear Valued users,
Thanks for raising this issue with us.
We are aware of this situation, and the team is working on it.
We will update you on any progress.
I appreciate your understanding.
Zyxel Nebula Support
maybe it's a signature update…
this crash
this is ok… difference it's only app patrol signature0 -
And just now there was a FW restart without any action on my part.
I have the same problem here!
I can no longer access the web interface on an ATP200, and the Internet connection is interrupted every 2-3 hours.0 -
@Vagabound can you check signature version?
How can I achieve this?
All well and good, but I can no longer log in to the USG Flex 200!
I got a workarround from zyxel EU support, and it's working for my devices:
use the serial console to enter the debug mode
BootModule Version: V1.19 | Jun 07 2017 17:17:04
DRAM: Size = 4096 Mbytes
Press any key to enter debug mode within 3 seconds.
Type the following commands:
atcd 1
atgo
→ reboot of ATP whith the old firmware
Did Zyxel produce the same error again as in June 2022?
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
