FWA505 setup / troubles
hi, I got this one, as my basic research said I could rate limit the wifi part of it, using per SSID rate limiting, via Nebula. Maybe it was Gemini AI who tricked me IDK.
Lot's of Nebula stickers and QR codes etc on the box and router.
My findings:
1. The web interface, while nice, does not have the rate limit feature.
2. I tried following the quick start guide, it says to install Zyxxel Air app, but when I follow instructions it says "Product not supported." ?!?!?! What is this?
Not sure the app would support rate limit anyways though.
Funnily I found this Youtube video claiming it is working:
https://youtu.be/T_EJUWo-2ak?si=g10f2X9cibj_OECB
3. I tried the Nebula approach, which yes did not feel very consumer oriented, but eventually I got it in to an account and site.
But then I found it it can only be "lightly" managed via Nebula, no configuration, like set up of WIFI, SSIDs etc is working from there. Spent an hour on that :) I added SSIDs there but it had no effect on the wireles router. And yes within there is a rate limit per SSID function, but since its not configurable from there it has zero effect of course.
So I'm super confused about it all. The Air app, support or not. And does it even matter, can this or any other Zyxel indoor 5G router support rate limit at all? If only the local web UI had it…
I want to limit my cabin smart tv to use all bandwith it can when using streaming apps etc, it will go to 4K easily and the monthly GB quota is gone quicky. So I need to limit it…
Hi @mrkzedge
- FWA505 doesn't support per SSID rate limit. It only supports ACL rule with rate limit. You may check our user's guide page 102.
- FWA505 doesn't support Zyxel Air, we will correct the wrong information in the Quick Start Guide.
- Mobile router on Nebula only provides monitoring functions. Please access the mobile router's local GUI to configure it.
Please feel free to ask if you need help with the ACL setting.
Zyxel Melen0 -
Thanks for clarifying Melen. Yes Nebula / Zyxel Air instructions needs to be corrected it seems..
So I tried your suggestion in the ACL page in the local admin, I found it, but yes it lacks the Enable Rate Limit setting out of all of them.. :) Updated the firmware as well before so all should be recent.
Anyways it seems I'm out of luck with this router, but thanks for trying!
Hi @mrkzedge
Sorry for the wrong information in the User's guide. Additionally, if you need to have seamless wifi roaming requirement in your home, you may purchase our AP and set rate-limit for specific SSID for your TV.
You may refer to the following FAQs for more details:
AP rate limit setting:
- Nebula Cloud mode
- Standalone mode
WiFi roaming:
- Nebula Cloud mode: How to Set up Seamless Wireless Roaming on Nebula?
- Standalone mode: How to Set up Seamless Wireless Roaming?
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
