Zyxel Multy M1 frequently turning red and stops working
TimRo21
TimRo21 Posts: 5 image  Freshman Member
edited October 2025 in Multy WiFi System
at home I have a system of 1 primary Multy and 4 Satellites. Usually every week I have to restart 2-3 of them because they turned red and stopped working. This is not how I expected the product to be. Can anyone help here?
Products probably out of warranty. Purchase date 2 years ago now.
Thank you!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,364 image  Zyxel Employee
    Hi @TimRo21
    It seems like you are over the maximum number of satellites (1 primary Multy with 2 Satellites). We recommend that you create two sites (1 primary Multy with 2 Satellites and another 1 primary Multy with 1 Satellite) to use.
    Zyxel Melen
  • thopv75
    thopv75 Posts: 2 image  Freshman Member
    I read somewhere that the Multy M1 can support for maximum 4 satellites.
    Actually, I have one primary and three satellites and they work well.
  • TimRo21
    Thank you very much for your answer. How would you implement this in a house with 3 floors?
    The only Primary is sitting at the Router and spreads the connection to all the satellites.
    Would it help to put a Ethernet Cable up to the highest floor to create another Primary one?
    Do I have to create 2 different networks then so I can use 2 Primarys? So basically 2 AP's and then connect 2 and 1 satellites to them?
    Thank you for your help!
  • Zyxel_Melen
    Hi @TimRo21
    About your question, we still recommend following our previous suggestion.
    Zyxel Melen
  • TimRo21
    I know, thats why I asked how to implement your previous suggestion.
    Thank you!
  • TimRo21
    So I tried it with just 2 satellites connected and the problem still occurred. Anything else I can try?
