NR7101 Module Firmware Upgrade Fail
So why do @Zyxel send out wrong Firmware? Quectel says it´s a special version…..
I saw that too. Maybe there is some special configuration unique to Zyxel products? In any case, I hope Zyxel will fix the firmware upgrade soon!
I don't think there will be any updates. In a support ticket they answer me like this:
"from software development they tell me that the firmware was released for problems inherent to some specific geographical regions, i.e. it solves some specific problems which if not present, the update makes no sense. If there are no real connection problems, it is recommended not to carry out this update (hence the impossibility of carrying it out independently). In cases where it actually needs to be installed, following connectivity problems, remote access to the device must be left directly to colleagues in Taiwan, who will carry out the installation."2 -
There is always the possibility of getting and applying updates directly from Quectel from the page linked earlier. The latest version from Quectel is:
RG502QEAAAR13A03M4G
But is that the best approach in the light of potentially divergent update tracks? It might not be possible to go back to any Zyxel-specific firmware updates if a switch to the Quectel track is made.Zyxel really need to attend to this. It isn’t exactly a great look or great publicity to provide a firmware update that is broken.
3 -
firmware that is broken and they aren’t able to fix… ridiculous.
According to the release notes, the new release V1.00(ABUV.10)C0 was also optimized/tested for new LTE module FW RG502QEAACR13A04M4G _ZYXE - so I should update this as well - or !?
Bootbase version : U-Boot 1.1.3 (Jul 18 2019 - 14:58:57)
Firmware version : V1.00(ABUV.10)b2
Kernel version: 3.10.14
WLAN code version: V4.0.1.0rev1
LTE Module FW version: RG502QEAACR13A04M4G _ZYXEL
Although I already had my doubts about the old release V1.00(ABUV.8)C0 - after the LTE module FW update (RG502QEAAAR11A07M4G-RG502QEAACR13A02M4G.zip) I didn't have the AACR but the AAAR version on it, and on Releas notes was too the AACR!
Firmware version : V1.00(ABUV.8)C0
LTE Module FW version: RG502QEAACR13A02M4G _ZYXEL0 -
Ah yes, interesting observation there! So perhaps the update:
RG502QEAAAR11A07M4G-R13A02
in the advanced downloads section, here:
Is broken - indeed the zip file shows:
But actually this did not result in AACR bur rather AAAR.
2 -
Maybe Zyxel meant to post the AAAR version of R13A04, as the text of the webpage says, but loaded the AACR version instead, which is not a compatible upgrade.
Do you know if this is something that Zyxel will change @Bob_C please?
2 -
I raised a support ticket and received a fix involving downgrade to R11A07 to reapply the R11A07-R13A02 upgrade in a way that resulted in compatibility with the R13A02-R13A04 upgrade. I expect this fix will be made available for other users.
Can you share the FW download links?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
