NR7101 Module Firmware Upgrade Fail
  • Stosun
    Stosun Posts: 23 image  Freshman Member
  • monstrmprz
    monstrmprz Posts: 37 image  Freshman Member
    edited October 2024
    They removed the R11A07-R13A02 firmware from the download page 😂😂
    https://support.zyxel.eu/hc/en-us/articles/4403365084818-Zyxel-5G-Devices-NR-Series-Advanced-Downloads-Firmware-and-other-resources#h_01J7ZRPS4WKP2D0F6D46MPAEQ3
  • lynxthecat
    lynxthecat Posts: 10 image  Freshman Member
    edited October 2024
    Actually I’m rather impressed with Zyxel over this issue. These firmware updates look rather fiddly indeed, and the fix was sent to me only days after I raised a support ticket. Kudos to whichever engineer(s) resolved this behind the scenes. I am a bit reticent about posting the files without express authorisation from Zyxel. In the support ticket it was indicated to me that the page is going to be updated so surely the files will be posted there very soon?
    By the way, is anyone else running OpenWrt on their NT7101? Stock firmware manages a higher throughput, which is another reason why I’m impressed with Zyxel in respect of this device. Can always just stick with stock firmware, set bridge mode, and use OpenWrt on a downstream router to benefit from SQM (using cake-autorate), advert blocking and so forth.
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    What are they doing?
    New filenames but still not working?
  • lynxthecat
    Gents, give them a chance! Next step will be the upload of the downgrade I imagine.
  • Mayone78
    Mayone78 Posts: 46 image  Freshman Member
    First Comment Friend Collector Second Anniversary Community MVP
    And so is there a way to update from RG502QEAAAR13A02M4G version?
    Thanks!
  • lynxthecat
    Yes downgrade then upgrade twice as I wrote above. Files will surely get posted soon.
  • Jack3003
    Jack3003 Posts: 1 image  Freshman Member
    Hello
    First You have to downgrade from R13A02 to R11A07 with this link below
    R13A02 to R11A07
    then you have to download the new file from their support
    and update to R13A02 then update from R13A02 to R13A04
    regards
  • SELBERG
