NR7101 Module Firmware Upgrade Fail
well, not if you select mode band lock in SA. and [after replacing you return in NSA will still be actively selected. You have to wait a while between changes, sometimes when you change from NSA to SA you may log out and then it won't catch your record. These changes are most stable when connected to the Zyxel Wi-Fi network
later I will post a link on YouTube with instructions on how to do it all step by step
https://youtu.be/eocrJK4B8Sc
Hi, i bought this cpe today. Can you say me how much time get the modem to reconnect after a disconnection? Here in my country isp disconnects forcely each 4 hours. Is there any difference between 13a02 and 13a04 about this?
More, can i use 13a02 modem firmware with V1.00(ABUV.10)C0 router firmware version? Didn't understand if 13a04 is better o worst them 13a02.
Are you sure it is a module problem and not a firmware v10 problem? Do you tried sto use new module with v8 firmware?
I suggest you to keep 13a02 modem firmware with V1.00(ABUV.10)C0.
Mine has 13a03...
Will V10 allow b38 carrier aggregation? Any other improvement?
I can confirm than with V10 i have b38 carrier aggregation now, but i can't see b7 and b38 togheter. Is it expected behaviour?
how to roll back an update from ZYXELR13A04 - back to G502QEAAAR11 ???
- 415 Beta Program
- 2.4K Nebula
- 147 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 262 USG FLEX H Series
- 271 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
