Inquiry about FWA515
hi
I have a router FWA515
I have a few questions:
- How do I know the processor temperature?
- I want to combine the 5G N77+N78 frequency.
- What are the SSH commands?
- What are your tips for increasing performance?
Thank you for All
Hi @misyscom,
Welcome to the Zyxel Community!
Regarding your questions, please refer to the following information:
- CPU temperature
- Unfortunately, the CPU temperature information is not accessible at the user level.
- Combining the 5G frequencies
- Please log in to the Web GUI and navigate to Networking > Broadband > Cellular Band > Band Management. Switch "Band Auto Selection" to the left to disable auto mode, and then manually select the cellular bands supported by your ISP for a more stable Internet connection. After the selection, click "Apply".
- SSH commands
- Could you please share more details, such as what specific information or configuration you would like to access through SSH? This will help us provide a more accurate and relevant response.
- Performance improvement
- Would it be possible to share your current network environment and application scenario? This will help us suggest more tailored performance recommendations. In the meantime, you may also refer to the following FAQs for tips on improving and verifying mobile router performance:
- What is a good 5G Cellular Signal of mobile router? — Zyxel Community
- How to improve Intermittent Router Connectivity Issues — Zyxel Community
- [Mobile router] How to resolve the issue of slow and intermittent Wi-Fi connection? — Zyxel Community
- How to improve Mobile Router connection by implementing daily reboot Maintenance? — Zyxel Community
- How to improve cellular WAN signal strength with external antenna? — Zyxel Community
Zyxel Tina
1 - CPU temperature
Thank you very much.
CPU temperature. This is very important.
I have seven FWA515s and I'm concerned about the temperature.
Thank you.
Hi @misyscom,
Thank you for your feedback. Currently, the FWA515 does not support access to the CPU temperature at the user level. Regarding the importance of this feature in your case, we will forward your request for evaluation and consider the possibility of adding it in the future.
Zyxel Tina
waiting ….
Hi @misyscom,
The request has already been submitted to our development team for evaluation, and an idea post has been created on your behalf. We appreciate your patience while we monitor the votes and comments as part of our evaluation process. Please don’t forget to give it a vote if you also like this post.
Zyxel Tina
zyxel fwa515 Can the IMEI be changed?
Hi @Saleh1212,
Please note that the IMEI is a unique hardware identifier. For security and regulatory reasons, IMEI numbers on FWA515 cannot and should not be modified by users. Thank you for your understanding!
Zyxel Tina
Hi @Saleh1212
I’m curious, why do you need to change the IMEI ?
Does it support eSIM? 🤔
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
