Zyxel FWA510 Stability Issues
dann3s99
dann3s99 Posts: 2 image  Freshman Member
Hi everyone,
​I am looking for some help with my Zyxel FWA510 (running the latest firmware). I am using it with a Telia SIM card in Sweden.
The Problem:
My connection is very unstable. The router frequently drops the internet connection. When it stops working, the "Globe" LED changes from Blue (5G) to Green (4G), but even though it shows a green light, there is no internet access at all. The only way to get it back online is a manual reboot.
What I have tried so far:
  • ​I tried locking the bands to NR5G-NSA and selecting specific bands (n28 and n78) to prevent "jumping" between 4G and 5G.
  • ​I have configured the APN manually to online.telia.se with PDP type IPv4 (and also tried IPv4/IPv6).
  • ​I have tried reverting settings to "Auto Selection," but the issue persists. The router seems to "freeze" or lose data routing during the handover between 5G and 4G.
My Goal:
I want to achieve a stable connection where the router doesn't "freeze" when the signal fluctuates. I would prefer to stay on 5G, but most importantly, I need the internet to stay alive without requiring a daily reboot.
Specific questions:
  1. ​Is this a known bug in the latest firmware regarding the 5G/4G handover?
  2. ​Are there specific LTE "anchor bands" for Telia Sweden I should lock/unlock to make the NSA connection more stable?
  3. ​Should I disable "Network Monitoring" or any other specific setting to prevent these freezes?
​Any advice or stable configuration profiles for Telia would be greatly appreciated!
