VMG3925-B10B drops 5GHz wireless several times a day - HELP!
Hi Zyxel Support
I too, am experiencing these issues on the same router from Hiper. Since you said that I should not change the fw version, should I then not update it when the patch is released on June 17? Then what should I do.
Hi JustPretender/ lauowolf,
V5.13(AAVF.13)C0 fw is ready on website, you can download it now.
Hi danielnielsen,
The patch with V5.13(AAVF.11)C0_20180409B is included in 13C0, you can use this one. But I suggest you can contact with your ISP first if it’s need do any settings for Hiper network.
Hi
I have the V5.13(AAVF.11)C0_20180409B on the router at the moment.0 -
Hi ChrisM,
So, I've upgraded and the situation is the same. Other suggestions?
Dear Zyxel_Support_CPE,
The download page[1] links to release notes for the latest firmware release. When I read the release notes[2] there is a section titled "Modifications in V5.13(AAVF.13)C0" on page 11, but nothing is mentioned about any 5Ghz issue.
Are you an official Zyxel representative?
Is this issue publicly acknowledged by Zyxel?
[1] https://www.zyxel.com/us/en/support/download_landing.shtml
[2] ftp://ftp.zyxel.com/VMG3925-B10B/firmware/VMG3925-B10B_5.13(AAVF.13)C0_2.pdf
Hi JustPretender,
We did internal testing for a long time, can you please describe more detail you encounter in 13C0 fw?
Hi thomaslkjeldsen,
The solution was included in V5.13(AAVF.13)b1 version; you can refer to page 13 “5G beacon” issue.
- 603 USG FLEX H Series
- 481 News and Release
