FWA710 losing 5G
Hey Guys!
Had my FWA710 working great for some months now, but recently it loses 5G and won´t switch back to it. Once I restart it it´s working again.
I´m on the latest firmware V1.17(ACGC.0)C0, 4G and 5G Signal pretty strong.
Is it a bug? Compared to the NR7101 the available firmware is pretty old and there´s no automatic-reboot option available.
Thanks for any help!
Best Answers
Hi @spigias
To start troubleshooting the issue with your FWA710 losing 5G connectivity, please follow these steps:
- Upgrade Firmware: Ensure your FWA710 is updated to the latest firmware version.
- Check 5G Signal Availability: Verify the 5G signal strength in your area. You can use the nperf website to check signal availability by selecting your Country, City/Province, District, and Carrier (Operator). Alternatively, contact your ISP to confirm 5G signal availability in your region.
Could you also provide us with the following details?
- What actions were taken before the connection drop occurred?
- How frequently does the connection drop happen? Is it random or periodic?
- Can you describe your network setup, including any devices connected to your FWA710?
If your FWA710 is managed via Nebula cloud mode, please enable Zyxel Support and provide us your Nebula org and site name, so we can gain a clearer insight into your device configuration.
Kay
I agree with you, the available firmware is pretty old compared to NR7101…. 4 days older lol……
So there is no scheduled to fill in, sounds bad….
Do you use Auto or what?
If auto i suggest you change it….
Hi @psmworld
You may refer to the guide suggested by @SELBERG or check out this article for further troubleshooting:
Additionally, if you would like to set up a scheduled reboot on the Nebula FWA710, please ensure your device is registered on the Nebula Cloud mode. Then, you can configure it under Nebula CC > Site-wide > Devices > Mobile Router > Maintenance.
If the issue still persists, please back up your configuration file and take a screenshot of the cellular info to show the signal level (Homepage > Cellular Info > click ">" to open the full page and take a screenshot of the entire page). Then, provide us with this information via private message. This will give us a clearer insight into your setup and situation.
Kay
Hi!
There are several newer firmware updates for NR7101 besides the official Download-Section. https://support.zyxel.eu/hc/de/articles/4403365084818-Zyxel-5G-Geräte-NR-Serie-Erweiterte-Downloads-Firmware-und-andere-Ressourcen
FWA710 is not included in this.
The FWA710 does not have Schedule at the monent! Only manual reboot available.
And it also does not have single selections of 5G. Only Auto (4G/5G-SA/5G-NSA)
Hi @psmworld
The option "NR5G-SA" in Cellular Band Access Technology refers to the pure 5G signal. From my end, the FWA710 does have this single selection of 5G. To gain a clearer understanding of your situation, could you please provide a screenshot of this option selection?
Additionally, if you are still having trouble connecting to the 5G signal after following the guidance provided above, please send us your configuration file and a screenshot of the cellular info (Homepage > Cellular Info > click ">" to open the full page and take a screenshot of the entire page) via private msg.
Kay
Hi
I experience the same problems some weeks now. Basically 2 things happening in the FWA710. The 1st is that is shown that connection exists, it has ip correctly but it doesn't have internet and is disconnected from nebula.
The 2nd is that it shows that, "Waiting for SIM signal" with no internet off course and no connection to nebula again.
In both problems a reboot resolves the situation but lately its happening constantly many times during the day. I took the router in work also and is happening there in a different antenna.
My provider is Cosmote Greece and we still have 5G-NSA even though the provider is ready to switch to 5G-SA in the upcoming weeks. I have tried all the possible combinations in Cellular Band settings in Access Technology and in Band Management with no luck
We really need a fix here for this or at least the ability to have a watchdog to restart the 5G module if the internet is lost after some time and is persistent.
My APN settings are manual and the Wi-Fi is disabled in the device. The problem is not with the sim because it resolves after a reboot and off course i had tried a newer sim with the same results. If you take the sim and install it in a phone or in another 5G router (i have a Huawei CPE Pro2 also) this is not happening.
Please do something, i love the router but i cannot stand this problem.
Hi @bluechris
To better understand your issue, could you please share how often you encounter it (e.g., how long after rebooting does the issue occur)? Additionally, please enable Zyxel Support on Nebula CC and provide us with your organization and site name.
Kay
To prevent any misunderstanding regarding the screenshot mentioned by @SELBERG , it is related to the vulnerability CVE-2024-0816.
This buffer overflow vulnerability in some 5G NR/4G LTE CPE, DSL/Ethernet CPE, fiber ONT, WiFi extender, and home router devices could allow an authenticated local attacker to cause DoS conditions by executing the CLI command with crafted strings on an affected device
The potential risk is from the LAN side rather than the WAN (Cellular connection) side, meaning the affected FWA product will not be impacted unless the device owner intentionally attacks their own device.
For more information, please refer to this security advisory post:
Zyxel security advisory for buffer overflow vulnerabilities in some 5G NR/4G LTE CPE, ...
Therefore, the difficulty with the 5G connection is not related to the vulnerability CVE-2024-0816.
If you encounter any 5G connection difficulties, please fine-tune your device using the troubleshooting guide mentioned here:
If the issue persists, please share the following information for further troubleshooting:
- Enable Zyxel Support on Nebula CC and provide us with your organization and site name.
- Your device configuration file.
- Cellular info showing the signal level (Homepage > Cellular Info > click ">" to open the full page and take a screenshot of the entire page).
- Describe your symptoms, including the frequency of the issue.
Kay
Dear Kay
The problem occur lately constantly during the day, the night it behaves better but there are days that the modem doesnt want to connect nowhere.
I enabled the support, my organization site name is HOME and site name is BlueChris
Kind Regards
Chris
hello, i am from Greece too , did you find a solution?.
i have a similar problem since yesterday the router appears to be connected to 5g but no internet is passing through. when i switch to 4g mode it works again and after a while i can enable 5g again and it works too.
- 441 Beta Program
- 293 Service & License
- 461 News and Release
